2023-09-27 01:05 PM - edited 2025-05-21 03:14 PM
Issue creation is a Pro feature in BIMx Mobile, introduced on iPhones and iPads in September 2023, and later on Android.
This collaboration tool integrates BIMx into architectural projects’ revisioning workflows by sending annotated 2D/3D Issues to Archicad’s Issue Organizer via BIMcloud. Moreover, Teamwork is only one option of many: the BCF-compliant issues can also be saved locally and shared via your preferred method like email or AirDrop.
Signing in to BIMx automatically enables Pro features for members of eligible companies. Read more: BIMx Licensing.
You can also try Pro features in the built-in demo model.
Issue creation is available in Hyper-models exported from Archicad 27 or later.
Get the latest BIMx app:
- iOS and iPadOS: Apple App Store
- Android: Google Play
Follow the workflow step-by-step:
You have various options to create a new issue:
Issues have the following components:
You can add hand-drawn markups by editing the viewpoint from the ‘...’ menu:
Draw your markup to the attachment with the 6 predefined colors, and save the edited viewpoint:
The issue’s preview (highlighted with a gray frame) can also be changed with the ‘Set as preview’ button. If the issue has no viewpoints, the Hyper-model’s project preview image will be added automatically.
Export begins with selection. Tap ’Select’ on the Issue list:
You can select issues one by one, or with the multiselection function for all the issues, all the drafts, or all the exported issues:
After selecting the issues, use one of these export options:
Your message will appear in Archicad 27 with a new ‘Import issues from BIMx’ button. With this new Archicad function, the recipient can add the issues to the Issue Organizer and start resolving them:
Archicad will send an automatic notification message to the BIMx user about the successful import.
Use External IFC ID – enable it if your 3D model includes elements from external software (anything but Archciad). This setting overrides elements’ unique ID saved into the issues included in the .bcf file. Activate the toggle if you wish to process the issue outside Archicad. By default, the toggle is disabled.
After exporting an issue, it cannot be edited anymore in BIMx to prevent unintended duplicates. If you open an exported issue, the edit function will create a copy.
The easiest import method to Archicad is the teamwork message described above. In the case of a local export and any share type, issues can be imported to the authoring software as generic BCF files. See how to import BCF to Archicad.
Good to know:
Any questions regarding issue creation? Feel free to open a discussion on Graphisoft Community's BIMx Forum or contact us at [email protected].
