2016-06-14 09:33 AM - last edited on 2023-05-09 03:51 PM by Noemi Balogh
2016-06-14 10:15 AM
2016-06-14 10:33 AM
2016-06-14 12:08 PM
2016-06-14 12:22 PM
methy wrote:It is not at all complicated, as anyone can do it manually by rendering projections of specific elements, saving all resulting textures as Surfaces and manually applying resulting surfaces to BIMx model.
You make it sound easy
methy wrote:BIMx supports that. You need to change so called BIMx "Info Set" on the basis of specific Schedule when you create a BIMx Hyper-model document and all objects in your BIMx model will have links to any Internet address you want. In essence, while viewing Hyper-model in BIMx, you will be able to select any object and if you did setup your BIMx Info Set correctly and had URL field as property field in your objects — you will see the link that will open to any Internet resource, PDF or web site in you iPad's default browser or filetype-related application.
Hyperlinks to external documents such as pdfs
2019-08-14 03:47 PM
Erwin wrote:Hi Erwin, how is using Twinmotion to produce a BimX possible? Apologies if I've misunderstood what you meant here..
Twinmotion and Lumion offer this and I think some people are using unreal engine, but that requires a bit more work.
BIMx offers other things, especially with pro with the presentation of 2d information along with the model.
2019-08-15 09:22 AM
ponaelius wrote:The question asked was about the 3D presentation rendering of BIMx at the time, Twinmotion is a different option of sharing the 3D model with your client that has nothing to do with BIMx. It is running on the unreal engine these days.
2019-09-13 01:06 PM
