How to customize or adding of element info in bimx
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-02-01
06:14 PM
‎2023-05-09
02:22 PM
Noemi Balogh
‎2019-02-01
06:14 PM
what i concerned is how to adding info such as length of element etc. especially because now i am working with road design.
Thanks a lot
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-21 05:25 PM
‎2019-02-21
05:25 PM
hello,
i think it would help if you explain more detailed what you want to customize and which infos you want to add ..
you can customize the 'titles' e.g. 'Building Material / Profile' in the schecule that you chose for each element-type.
see @ '•Select Schedule' here https://helpcenter.graphisoft.com/user-guide/77209/
if you want to customize the 'values' e.g. '0.200m' to '20 cm' you can create a new attribute and recalculate that (from AC22 on).
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-23 09:18 PM
‎2019-02-23
09:18 PM
You had to select the nomenclatures just when you choose the bimX export
You can choose a lot of nomenclatures you had to create to this aim
BimX is the best way to communicate BIM and probably the simpliest way too
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-03-08 06:33 PM
‎2019-03-08
06:33 PM
If you create a schedule of the information you want to make available in the BIMX model, you can then link that schedule to the BIMX export.
I have a set or properties that store useful text and hyper-link info that I can then make available to the BIMX viewer. Its very powerful and if you set it up in Publisher, everything gets updated each time automatically.
Tim Ball
AC26, iMac
User since V5
AC26, iMac
User since V5
