2017-05-01 07:55 PM - last edited on 2023-05-09 04:19 PM by Noemi Balogh
2017-05-04 01:59 AM
2017-05-04 10:25 AM
2017-06-08 04:07 AM
2017-06-11 08:02 PM
2017-07-21 08:44 PM
2017-10-24 10:00 AM
"Yes the engine of Bimx need improvement"It is true that the rendering engine of the Bimx makes bad shadows especially
2017-10-24 07:15 PM
Christophe wrote:We use global illuminate almost exclusively to obtain better bimx results but seeing what is possible with other graphic engines, I still believe that a forward looking graphisoft needs to be pushing toward stronger graphics or risk being left behind. Looking at what twinmotion does -
BimX uses a GDL rendering. This one is neither good nor bad it is adapted to its use: to consult the 3D model as easily as the 2D drawings.
but to expect bimX to have a photorealistic rendering is not its goal and that's why the bimX format is very powerful. It's about using it for its function. Small improvements need to be made but a photorealistic rendering engine seems out of place for bimX.
We can also simply note that global illumination, which improves the rendering, is very time-consuming :
Just here on Archicad-Talk
It is possible to make beautiful and simple rendered bimX but it will remain in my opinion a BimX and not photorealistic imagery
2017-10-24 09:36 PM
