BIMx
About BIMx (mobile, web and desktop), connection to BIMcloud, and related technical questions.
Strange Object in Background
hi all,
i all our BIMx models we get that strange grey "object" (not selectable) some hundred meters under our actual model (web and mobil) What is that? Anyone has that too? (Its visually annoying)
Thanks for any hint
AC24 4018 INT, Win10, Quadro P2000, Xeon, BIMCloud
Roland Szabo
Dear Florian,
That grey stripe is the edge of the default Skybox image used in older BIMx app versions. We have already changed this background in all the mobile applications, please install the latest build. The next update of BIMx Web Viewer will also include the new Skybox.
Also, you can easily set a different background for a 3D model in Archicad. More info can be found in the Export Options for a 3D View described in this article.
Kind regards,
Roland Szabo
BIMx Product Manager
Thank you!
Best Regards, Florian
