‎2011-06-02
12:52 AM
‎2023-05-09
01:15 PM
Noemi Balogh
‎2011-06-02 01:46 AM
It is possible to restrict where the camera can go or fly. Simply create a rectangular box using the Slab tool that encloses the navigation area (this could surround the entire model, or just part of it), aligned on the axes. It does not matter what material you are using, but you must set the ID value for this element to “zlimits” or “ZLIMITS.” During the conversion to VBE from ArchiCAD, this element will be detected and the camera movement will be restricted to this volume.
‎2011-06-02 01:54 AM
‎2011-06-02 03:29 AM
flamingjawa wrote:Sadly, you need it most when flying. Nothing worse than watching a director flying through the earth during a masterplan presentation.
Also this technique only works for simple walking
