heathldesign
can't login to Bimx app
Hey there,
I've had this issue before, but don't recall how it was resolved. when i open the BimX app it now wants me to sing in. it worked fine last week, and i haven't signed out so i don't know what's going on. when i enter my login info, it says " to open additional models with all the latest features login to your graphisoft account. which i can't seem to do. i click ok and it sends me back to the login window. rinse and repeat. though i have obviously signed in to get to this forum, so my login info is correct.
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
1 Solution
Marc H
Hi - It seems something is going on with BIMx lately. I, too, have had to sign in frequently over the past few months. About a month ago, it would not let me in.  My memory of it is unclear, but I believe I did the following:
- Re-started my iPad
- Waited some hours thinking it might be a GS server issue, which might have been the case.
- You might also try re-installing the app. However, be aware if you delete the app, you delete not only the imported model copies, but also any draft issues you have created in your models!  Best to export these out beforehand.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Go to post
Marc H
heathldesign
I ended up quitting BimX and restarting. that seemed to solve it for me.
