exterior shell model only?
hello,
is there a way to publish a model of the exterior only and does not allow you to go inside? I want to share a model with a client put it is not finished out on the interior.
Thanks
3 Replies 3
If internal walls were on their own layer you could turn that layer off, as well as any internal fixtures and furnishings. When you Save As from the 3D window only visible items are exported. Your client could still go inside, but there would be nothing for them to see.
thanks,
i do layer like that, I was hoping i could lock the door and keep the owners out.
LOL
DGSketcher
Legend
You could try filling the inside with a big slab temporarily, the BIMx app might then stop entry into the building. It could also stop them looking through the windows if you haven't used obscure glass.
