Collaborate forum
Bimcloud for version 25
Eric Milberger
Is there a Bimcloud for version 25?
Eric Milberger, Architect | Master Planner
Archicad 25
AecoSim
Microstation
Windows 10 64bit
Remote - i7-8550U CPU @ 1.80GHz, 2001 Mhz, 4 Core
Office - Processor i7-8700K CPU @ 3.70GHz, 3696 Mhz, 6 Core
11 REPLIES 11
hybrid
Hi. Now one BIMcloud for all * versions. In my opinion, starting from 19 to 25. The choice of the version of Archicad is carried out after installing the program.
After creating the first user (not to be confused with Masteradmin)
a window with a choice of the Bimcloud type comes out. Bimcloud Basic or Bimcloud (Full). When choosing BIMcloud (full fledged) it supports all Archicad versions. When choosing BIMcloud Basic, you only have to select one version of Archicad.
https://graphisoft.com/downloads/bimcloud
AMD R7 2700 3.8@GHz | 32 Gb RAM | SSD | GTX 1050Ti
You can also install multiple BIMcloud Basic for your server. For example for AC24, AC25. But this is not recommended by Graphisoft (Russia). When using multiple BIMcloud on one machine (server), some problems may arise. For example, you will have to change ports several times. If you need help, please contact.
Noemi Balogh
Both BIMcloud 2021.1 and 2021.2 support Archicad 25. Based on the language version you use, I suggest to download and install the latest version available (2021.2 preferably).
Link: https://graphisoft.com/downloads/bimcloud
Noémi Balogh
Customer Engagement Expert, Community Admin
I had 2021.1 and it did not recognize 25.   And had trouble finding new version.  Only had found old.   Your link got me to where I needed to be.   If.this is the route,  why not a way to install a new version which utilizes or copies all setups Luke user.   And houses all requested versions.   But also a possible Update.  A full update.   Updates version. All projects, and keeps old version
Archicad 25
AecoSim
Microstation
Windows 10 64bit
have you reinstalled? or with already installed BIMCloud looking for? Just as I know BIMCloud 2021.1 has been supporting AC25 since May. I have 2 BIMCloud installed now, 1 for AC24. 2. For AC25. I just exported users from version 24 to version 25.
My server was 2021.1 - and I just removed it and established a new server.
This probably could be a little friendlier.
Install new
Unistall old if you wish
Maintain all servers with different ports found by the SW.
The migrate - Drag and drop from one server to another
There are just gaps in the instruction and some in what would be typical for current software.
Archicad 25
AecoSim
Microstation
Windows 10 64bit
You did not have AC25 support on version 2021.1 during installation? Back in May, when I participated in BETA AC25, I installed BIMCLOUD, it had AC25 support
I did not but did for AC24 - and at the top it said for AC24, when I installed I had to declare which version.  And I was using 24.
I am small right now but work on large projects in Bentley - wanting to start are next big project in this product and trying to anticipate where hassles will be.  Our large projects typically span 2 years
Archicad 25
AecoSim
Microstation
Windows 10 64bit
I should add it is jut my getting used to a process.  Non of the prior packages required file upgrades to a different version.  Atchicad gives a better product and this is probably the trade off.
My preference would be a server that loaded all versions - opened your file in the appropriate version and asked you to update (yes/no) or deny opening if there is no choice.
Archicad 25
AecoSim
Microstation
Windows 10 64bit
Apart from BIMcloud Basic, BIMcloud and BIMcloud as a Service can handle multiple versions of projects at the same time. Migration between Archicad versions though still requires both Archicad version (the one you used and the one you wish to migrate to.) - but this might be another story, and probably fits more to the Wishes forum.
Noémi Balogh
Right - for Now I am stuck in the Basic Version.  And for a small office and team of Engineers it is all.  My biggest issue is migrating up as there are NO other Archicad users in my Area and limited.  I don't have a background with Engineers in Nashville or Atlanta that use this product and it may not be cost effective.  I love the product but it is very hard to create with others.
None of my Engineers are willing to make the investment.  We all made our investment 20 years ago in SW and this is a big commitment.
Now away from the rant.
Basic is perfect for a small team and small firms.  Just could use a little more growth to help us convince other to use SW that is not taught in schools here nor it is unknown in our region.
Archicad 25
AecoSim
Microstation
Windows 10 64bit
