Complex tekla elements via ifc to native Archicad elements?
Mats_Knutsson
Getting CL columns from struct and can't get them to import to AC as parametric columns. Is it at all possible? The columns come with plats and bolts which I exclude. Attach shows a cleaned up CL column.
The reason I want to investigate this is because I want to use BM priorities. I just did it with a revit model and it worked great (simple column and beams...nu fastening stuff...
/M
AC 25 SWE Full
0 REPLIES 0
