2007-11-07 07:35 AM
2007-11-07 07:52 AM
2007-11-07 08:09 AM
Erika wrote:
You'll need to put in a filter so it will exclude/include only the IDs from the house you want.
2007-11-07 08:59 AM
2007-11-07 09:55 AM
Matthew wrote:That's right.
I gather you are scheduling the IDs.
2007-11-07 07:02 PM
2007-11-07 10:59 PM
siteline wrote:I need the module brought into each corresponding project to maintain its door & window ID numbers as both projects will have a door & window schedule.
I just went into the module file, selected all of the windows and changed their ID to "EX," then did the same with all of the doors.
Creating an exclusion in the schedules for "ID is not" EX left all of the doors and windows of the module out of the schedule.
2007-11-08 05:18 PM
2007-11-08 05:39 PM
2007-11-08 11:33 PM
siteline wrote:If that's the case, then it's a pretty easy workaround. Just create another story with zero height at the same elevation as the other story.
I just tried the module layer suggestion and it didn't work. Excluding the items by Story does work, but again, that's only if your module is on a different story.
