Collaborate forum
Graphisoft BIMcloud Basic 24-25 stopped working
Hi everyone!,
Recently I made an update for Windows 10 Pro, to 21H1 version. After that, BIMcloud Basic for AC25 was installed and configured. At the end none of BIMclouds works (Teamwork users can't connect). The only possible connection to BIMcloud Manager is through server. Did any of you Guys, has simmilar issue?
Kind regards,
Karol
OPENBIM does works!
ArchiCAD 22/23/24/25/26
AMD Ryzen 7 3700X, 32GB RAM, GeForce RTX 2070, Windows 11 Pro
MBP 14 M1 Max 32GB
http://www.bimfaktoria.pl/
1 REPLY 1
SeRohde
"none of BIMclouds" Is there just one or several? I am in a hurry, so here are some quick thoughts:
I would login into BimCloud Manager; Goto:
"Server" -> "BIMcloud (basic) Manager" -> Settings -> Connection Settings
"Server" -> "Server-YYYY-MM-DD" -> Settings -> Connection Settings
Press the "Test Button" each time
Maybe DNS isnt working.
- Check the PC-Name and make sure it does not contain spaces or exotic letters
- Check the PC's IP-Adress
- Make sure its a fix IP-Adress, note it down (like 192.168.0.25)
- Check if in the settings above (Connection settings for Manager and Server) the correct PC-Name and Port is listed
Like: http://PC-Name:25000/
- Add an alternative Entry, but this time with the IP instead of the PC-Name
Like: http://192.168.0.25:25000
- Check if the Firewall is blocking Ports
Admin of BIM [Cloud] [SaaS] [Server] | AC 19-25 [Win&Mac Clients] | VM's
