IFC Translator missing in imported .pla file
janbak
Every default translator is missing and I can not add a new one either.
Can this be because I am in a v25 and the file is made with v22? Should it matter?
felcunha
You can import the translators from the Template.
Just click on the import button (right to the information button down the window) and go to Defaults/Archicad/ folder.
Felipe Ribeiro Cunha
AC 26, macOS Monterey
More precisely,
C:\Program Files\GRAPHISOFT\Archicad 25\Defaults\Archicad\Archicad 25 Template.tpl
The same general path for the previous versions
C:\Program Files\GRAPHISOFT\Archicad xx\Defaults\Archicad\Archicad xx Template.tpl
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
