ā2021-11-05 11:15 AM
Every default translator is missing and I can not add a new one either.
Can this be because I am in a v25 and the file is made with v22? Should it matter?
ā2021-11-05 03:55 PM
You can import the translators from the Template.
Just click on the import button (right to the information button down the window) and go to Defaults/Archicad/ folder.
ā2021-11-15 10:14 AM
More precisely,
C:\Program Files\GRAPHISOFT\Archicad 25\Defaults\Archicad\Archicad 25 Template.tpl
The same general path for the previous versions
C:\Program Files\GRAPHISOFT\Archicad xx\Defaults\Archicad\Archicad xx Template.tpl
