2023-02-18 09:59 AM
When I export an IFC the tree is based on floors.
I want ot use the IFC for quantity surveying so I want to use my classification which is based on that.
Is there any way to export the file so the tree straucture will have the elements based on the classification so I do not have to edit the ifc again with the quantity surveing software.
The IFC manager does not give any option of editing this tree.
Greetings
2023-02-20 09:15 AM
frist you need to make sure your desired translator is set as preview (it will have little archicad logo next to it)
then, in type mapping you select 3 dots.
lastly, you select classification
