Update Excel exported schedule
SajW
Is it possible to update a schedule which was exported to Excel? Assume that I have added an extra column to the exported excel file, so when I re-export the schedule, I do not want to loose the extra column, currently the whole excel file is updated as per my knowledge.
3 REPLIES 3
Hello,
Any additional changes in Excel can not be imported into AC because these changes can not be organized within the model
You must :
- create an element nomenclature from AC with one or more properties to inquire
- export the file xls from the menu File / interoperability / classification and properties
- modify only the column or columns previously created by AC
- save the xls file
- import the xls file into AC from the menu File / interoperability / classification and properties
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
SajW
Hello,
Thanks for the information.
But I do not need to import back the information, it is maintained as an external database.
I think you will need to save as a new Excel file from Archicad.
And then use some Excel magic to merge the new file into the original one.
Learn and get certified!
