LaszloHatvani
Schedule xml import in Archicad 29 is removing fields
Some Schedule fields are missing when importing back a previously exported a Schedule xml. (tried in INT and FRA)
Steps to reproduce:
  • Open "Bad schedule export.pln" file
  • open schedule "Lot 01 Office - DQE détaillé"
  • 3D Axonometry is visible at the 8. column
  • export Schedule xml for "Lot 01 Office - DQE détaillé"
  • Import back the exported xml
  • In the new Schedule the 3D Axonometry is missing in columns and in fields too
Is it a known bug?
I tried this and I got the same result - for some reason, the 3D Axonometry field disappears from the list of Schedule Fields in the imported Scheme.
I checked the contents of the exported XML in an XML editor, and there, I could find an item called Axonométrie 3D, so the export was fine, which makes me think the error must have occurred during import.
I suggest that you report this bug to your local reseller for further investigation.
