how can i open a file from archicad11 in archicad12???heeelp
heeeey guys hope ur oing well,plzzz let me know if there is a way to open a file from archicad11 to aac12
thaaaanks...
1 REPLY 1
'File', 'Open' and select the .pln should work fine in AC12.
Bear in mind it will be loading the old AC11 library parts which won't work with the new partial structure display option apparently.
