‎2021-10-14 08:57 PM
Is is possible to map custom properties to IFC?
‎2021-10-15 11:11 AM
As I understand, You can map custom properties to ifc properties by using the IFC translator and the property mapping dropdown dialog by setting a mapping rule for the ifc property. i don't believe that you can use expression properties though -- could be wrong
‎2021-10-15 11:28 AM
Just double checked -- apparently they can
‎2021-10-15 12:25 PM
yes - i just discovered and tested - property expressions can be mapped to IFC.
Gerry - do you know if anyone has automated IFC mapping of custom properties based on schedules?
‎2021-10-15 02:20 PM
@gdford wrote:do you know if anyone has automated IFC mapping of custom properties based on schedules?
Don't believe so. What did you have in mind?
‎2021-10-15 02:40 PM
Well, lets say I have 500 custom properties I want to export with an IFC model. All of the properties are scheduled via various schedules. It looks like I would have to make 500 edits in the IFC translator to accomplish this task. So I am wondering if this could be accomplished via the API to generate the mapping using the schedules as a guide
‎2021-10-15 02:51 PM
This is definitely possible. Our reseller supplies a template with a very detailed set of properties that they have all mapped to IFC export.
When I last looked at the interface for this, it didn't seem to be very user friendly or for those new to IFC perhaps. I am glad they offer this service, since the task seems daunting.
