2010-10-27 05:40 PM
2010-10-28 12:21 PM
2010-10-28 12:34 PM
2010-10-28 01:34 PM
2010-10-28 01:39 PM
feio49 wrote:Then another setting to check is it the Door is set to "Projected" or "Cut" or "Symbolic" and whether setting it to something else makes any difference.
Revit door families in plan are typically represented with 2d symbols.
Maybe you only got the 3d model from the IFC import.
If that was the case, you have to redifine the door familiy (object?) to add the panesl and swing arcs.
2010-10-28 03:58 PM
2010-10-31 09:25 PM
2010-11-01 05:15 PM
