3D Studio Max
Is it possible to import an object created in 3D Studio Max?
4 REPLIES 4
Djordje
If it is in MAX format, no. There is a plugin for 3DS import. Try converting the MAX to DXF.
What kind of object?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Eduardo Rolon
From Max export as 3DS - this one you can import
optional
import 3ds in AutoCAD- clean and verfiy
save as either dwg or 3ds again
import to AC
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Along this line of thought.
I've imported a 3ds file into AC10 just fine.
Only now it's an Object. How can I convert
an Object into something editable?
Thanks,
Matt
Dwight
Fuggedaboudit.
All you can do is scale it, either proportionally, or not.
You can use a Solid element Operation to cut off the extra bits, but that is it.
Dwight Atkinson
