3D modell in dwg to archiCAD
By importing 3D dwg modell through MERGE /when I use xRef, it doesn't work me properly, I don't know why/, everything is imported as one big object.
Is there some way, that I can explode it in 3D?
Thanks
4 Replies 4
Eduardo Rolon
One option is:
1. select the object
2. right click
3. Convert to Morph
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
I've already tried it, but it doesn't split object properly. Strange combination of single objects.
Eduardo Rolon
Other options:
- Try another type of export from the original program
- Try exporting by partial selection and layers so that you don't get one huge object and instead get lots of small ones.
AC29 US/INT -> AC08
Thank you, i will try it.
