stefan
3DS Import
I used to be able to import OBJ-files into ArchiCAD with surface smoothing intact.
http://www2.asro.kuleuven.ac.be/asro/English/HOME/SBs/tutorial/tips/viz2ac.htm
(Explained with 3DStudio VIZr3, but this will work in Maya as well, since Alias|Wavefront was the inventor of the OBJ-format).
AFAIK, ArchiCAD 8.x doesn't read OBJ-files anymore
Another solution, slightly worse, but better then DXF for that matter is importing it as a 3ds-file (Maya should be able to do that, you might need to download some translator-plugins, though).
This 3ds-import was once mailed to me by some German ArchiCAD user and I can send the full plugin to you if you want (it was free, so I don't think I break any copyrights here).
Archicad-user since 1998
my Archicad Book
39 Replies 39
stefan
Options dialog
my Archicad Book
Ben Odonnell
Nice work Stefan.
I have never had a problem with the converter not working. It's great to be able to import 3DS file into ArchiCAD. The guys that have done this converter have even done a converter for Lightwave objects. It also works really good.
Cheers.
Ben
Ben O'Donnell
Eduardo Rolon
Steffan can you post a translation of the settings in the jpeg since you already know the language.
I think that having the jpeg as a reference with the options in english might help us spanish speakers with english as a second language and no german knowledge
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Ben wrote:
Nice work Stefan.
Cheers.
Ben
I can't seem to find the Lightwave importer, where can it be found? Plus, does it work with 8.1?
Ben Odonnell
The Lightwave one works with 7.0. But it's possable it's been or going to be redone for 8.1.
I'll find out for you and post my findings here.
cheers
Ben
Ben O'Donnell
stefan
Dutch speaking with French as second language (officially), but English as a practical second language and german as third.
Freestyle translation:
3ds zum gsm konvertieren = to convert a 3ds file into a GSM-library part
Koordinatentransformation = coordinate transformation
Massstab = unit size (that is, how is one unit in the 3ds-file interpreted)
Dezimalstellen = the number of decimals after the "," or "."
Untere Teil aud z=0 setzen = put lower part (of the whole file?) on z=0
Object-Schwerkraftpunkt auf ... setzen = put objects gravity center on ...
Falls erforderlich, SchwerkraftPunkt auf 0 setzen = when needed, put the gravity center on 0 (Don't know what the difference is with the previous option).
Fixpunkt erzeugen = create anchor point (hotspot)
Begrenzungsrahmen = bounding box
Nullpunkt = the origing
Schwerpunkt = the gravity center
Äussere punkte = the outer bounds
Grundeeinstellung = reset
Abbrechen = cancel
my Archicad Book
Eduardo Rolon
Gracias
AC29 US/INT -> AC08
Gorazd
Hi.
And to end with a positive note: a link to the updated version of this plugin: now also for ArchiCAD 8.1
http://www.gshelp.de/CDownloads/Downloads81.html
Link you gave is not working. Is there any other location to download 3DS import plugin for AC8.1? Or can somebody please mail it to me?
Gorazd Rajh
From AC 6.5 onward, i9-14900HX, 32 GB RAM, RTX 4060, Win 11
stefan
Here is the 8.1 version (APX only, so not usable on Mac).
my Archicad Book
hi,
does anyone have an english version of this add-on for 8.1 int.
thanks
