A10 Log Cabin Corners
How do you use the LHS Cross Corner tool in A10 ?
4 Replies 4
Brad Elliott
I haven't heard of it? Where did you find it?
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Log Home Solution (LHS) is a special version of ArchiCAD with a special library. Most of us don't know much about it, so while you wait for an answer here, it would be best to contact the reseller from whom you purchased it. Angie Izzie handles east of the Mississippi and Chris Clark west, AFAIK. If you are in a houseboat in the middle of the river, I guess you can flip a coin. 😉 GSNE handles Canada AFAIK.
http://www.visualmotion.com/loghomesol.htm
Very little info out there.
Dwight
If you don't own the Cross Corner tool, there's an easy trick to make cross corners that is only a couple of extra steps.
Assuming that you have a completed wall and slab arrangement:
1: Uniformly enlarge a COPY of the floor slab to the distance the corners should cross.
2: Select walls and use the ADJUST command to automatically lengthen each wall to the slab edge as required. This requires being selective in your wall selections - ie: not all of them at once.
DELETE the slab copy.
Dwight Atkinson
Pete
... or if you want a butt and pass or dovetail looking corner, you can use Dwight's method and then SEO to cut out the "teeth".
Pete Read
ArchiCAD 12; Artlantis Studio 2
MacBook Pro 2.4 Core2Duo, 2GB, OSX(10.5) and XPpro(SP3)
