AC 12 Door Schedule - Door widths with 4 digits
I just tried to use the door schedule in version 12 for the first time. When I generated the schedule I noticed that all door widths with 4 digits show up incorrectly. ie - A door with a 1,070 mm width shows up as 1,07"0. Please see door width in attached scheduled screen shot. Note: My dimensional preferences are set to plain millimeter. If someone knows what to do to fix this problem please let me know.
Solution:
Step 1:
Right click schedule in viewsets and open view setting
Under 2D/3D Document - dimensions: Plain Millimeter
Step 2:
ArchiCAD> Project Preferences scroll to Calculation units.
Length Unit: millimeter
These steps should be checked to make sure the format you wish to have is achieved
I would call that a bug, though it would be rare in practice because you likely wouldn't use metric dims and imperial calculation units at the same time. It must have been a glitch between the dimension standard saved with the project and the default calculation units of a fresh copy of 12 (US version I presume). But it's still weird because calc units are saved with the project too.
Even though it's a rare bug, it's a little unsettling to have multiple prefs affecting displayed values in a non-obvious way.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
