AC 14 to ACAD: polygonal drawing frame-rectangular viewport
Hello,
When exporting from AC 14 layout containing drawings with polygonal, non - rectangular frame, the corresponding viewports in paper space in Autocad are always rectangular.
I appreciate free -form framing in Archicad which sometimes helps prevent overlapping between drawings or with title blocks in the layout.
AC 13 did the same thing, with the same project file and same translator settings flawlessly.
I checked carefully drawing settings (including the new ones) and translator settings. This issue doesn' t occur only when "paper space with drawings as blocks" is chosen. With other options the problem persists.
Is this a bug or there is a hint - may be in registry settings?
0 Replies 0
