AC 17 opening dwg issues
Has any one had issues with opening dwgs in AC17?
I have a dwg file which was published from AC16 and every time I try to open it AC 17 crashes. File is only 5.18MB.
5 REPLIES 5
Just as an added note the file opens with no problems (although a little laggy) if Xref'ed on a worksheet. :?
Marton Kiss
Thanks for sharing this workaround. Please send the original DWG to our UK support and they will be happily assist you. We will check the DWG to address the problem in the code of AC.
Marton Kiss
Chief Product Officer
GRAPHISOFT
our UK support
At the rest of being slightly dim what are the contact details for the UK support team?
Marton Kiss
Oh sorry, here you can find contact details: http://www.bite.co.uk/pages/base.asp?rset=support&lg=logosupport1.gif&mlg=bbc_08.jpg&mlgid=item18
Thanks,
Marton
Marton Kiss
GRAPHISOFT
Two Hotfixes down, and a couple emails this issue is still on-going how can this be!!!!!!!
