Listing parameters in info box?
Is there a way to have the listing parameters show up in the info box, or somewhere where you can quickly edit the information?
3 Replies 3
Unfortunately not.
If you go to the Info Box page of the Work Environment Dialog, you can see for each Tool the available panels the display of which can be enabled and disabled.
David Maudlin
catbird:
You could create an Interactive Schedule with the desired parameters, so they can be edited in one window rather than opening and closing the Settings dialog box. This schedule could be exported to other projects once it is created.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Dave, Great idea, thanks for the tip!
Upgrading the hardware this week. Will update the signature soon.
