AC 19 to AC 16... how?
hi everyone. i will be working with a team stuck at Archicad 16.... ( and i am currently using V19).
what do you think is the best format to exchange data ?
thanks in advance
Eduardo Rolon
Download and install AC16 to your computer. Your reseller can get you the link or ask your colleagues for an electronic copy of the installer. Your license key should be able to run it without problems.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Erwin Edel
Should you have to save back to 16, you'll need 18 and 17 as well and 'save as...' from 19 > 18 > 17 > 16 and deal with the pain of no building materials as probably the biggest challenge.
Are they to work with you on the architectural model? Or are they providing some other sort of work? I'm wondering if IFC might be better to just share the model.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
