AC20 | Blank Door Schedule on Layout
This keeps happening... open up the Layout with the Door Schedule and only the headers display. Update Drawing and only the headers display. Open Source View from Context Menu, all doors are scheduling as expected. Go back to Layout, Update Drawing, and schedule finally shows.
I've got to think this is a bug.
How it appears on the Layout...
5 REPLIES 5
...and the Source View:
Katalin Borszeki
Hi Laura, could you please make a short screen recording of the issue and upload it to here and PM me that the file is there?:
https://graphisoft.sharefile.com/r-r0b36fa3934f4da1a
Thanks, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
Thanks, Katalin -- I've uploaded the movie. You can see that the schedule will only update if the View tab is open. Once the View tab is closed, and the schedule is Updated, the Drawing goes back to headers-only.
I have this same problem with a whole range of automated schedules, mostly ones listing out Zones with their area and name.
The files have been migrated from V18 to V20 and are in a teamwork environment.
Katalin Borszeki
Hi All, we have observed the file of the user. The reason of this phenomenon is a Missing Renovation filter: Right click on the Schedule in the Layout view and choose "Modify Source View Settings...". Here you can see that the active renovation filter is missing, it is possible that doors are hidden in it. (see attached a screenshot about this - Set the filter to "New Construction" and the data will appear) Best,
Katalin Borszeki
GRAPHISOFT
