2022-07-20 07:36 PM - last edited on 2022-10-04 01:09 PM by Oleksandra Vakariuk
After copying a stair from one 26 file to another if you edit its settings it resets all other display options.
another Moderator
2022-07-20 09:12 PM
Looks like when the stair is pasted in the file it does not read the MVOs from the current file.
The File from which the stair was copied that different MVO settings.
another Moderator
2022-07-20 11:30 PM
MVO’s are a nightmare. I often update them in the template file then export them out to import in to active projects. They won’t overwrite and all end up named with a ‘(1)’ after the name. Even if you delete the original versions and rename the new ones exactly the same all the views then as the MVO is ‘missing’
