Add-in for Revit 2017
Hi Folks!
On the Graphisoft website, I can not find the IFC converstion add-in for Revit v2017. Only 2016 is found, and our firm just installed Revit v2017 which is our only version.
Any insight on whether GS will provide a plug in for Revit 2017?
Will the v2016 plug-in work for Revit 2017?
Thanks in advance!
7 Replies 7
Revit 2017 came out only about 2 months ago so I guess there will be some more time before the compatible Add-In is released. Unfortunately I don't know when that will be exactly.
thank you. I thought this might be the case. We were able to get Revit 2016 and use the 2016 GS Plug-in
Best,
B
davdelven
Any new about this plugin update for R2017 ?
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
I asked the guys at GRAPHISOFT and while they did not tell me an exact date, they told me it should be released in the near future.
Da3dalus
Well, I noticed that the 2017 Revit Add-On INT update has been out for about an hour now, so let's bring the questions! So... FIRST!
Anyway, my question is, will this Add-In work with Revit LT 2017? We're looking for a way to do our own conversions. With the new Subscription system at Autodesk, we can download this on an as-needed basis. Obviously, LT is cheaper, and we don't need any other features.
Thanks!
Chuck Kottka
Orcutt Winslow
Phoenix, Arizona, USA
ArchiCAD 25 (since 4.5)
Macbook Pro 15" Touchbar OSX 10.15 Core i7 2.9GHz/16GB RAM/Radeon Pro560 4GB
No Revit LT does not support addins
Yes, Scott is right.
Revit LT does not support the Revit API. This means that you cannot access anything that is based on the API, which means no Add-Ins can be installed in Revit LT, including this Add-In.
By the way, the download link for the new Add-In is at:
http://www.graphisoft.com/downloads/interoperability.html
