ArchiCAD Connection for Revit 2015?
IFC Interoperability plug-in only works for Revit 2014 not Revit 2015.
Any suggestions or indication of 2015 version release?
17 Replies 17
I received the information from Graphisoft that they are working on it and plan to release it during this August. So keep you eye on the following web page:
http://www.graphisoft.com/downloads/interoperability.html
Marcus R
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/archicad-18-new-features-gui...
says:
The GRAPHISOFT ArchiCAD Connection Add-In for Autodesk Revit 2015 software (including Revit Structure, MEP and Architecture) is available free from the GRAPHISOFT website.
where??
Marcus
As I said: it is being worked on and will be released shortly.
Keep a eye on this page:
Probably at the time of writing this Help Center page it was supposed to be released by the time this help page went online, but it got delayed.
I am using Archicad17 and I need to collabrated with revit MEP 2013
what could be the best way to work?
such as IFC 2x3 is one of the way,,
some how I cant open Revit MEP IFC 2x3 file from archicad
I am looking for plug in at the moment
Naviswork is one otherway ,,, but it is hopeless(autodesk users uses it)
Any word on the release for ArchiCAD Connection for Revit 2015?
On the page I mentioned earlier there is still no Revit 2015 version so I must assume it is still in the works.
AndrewMc
Any chance of getting a heads up when the 2015 plugin comes on line?
I will check with someone at GS HQ and come back with some info.
The information I got from Graphisoft is that the plugin is very close to release, it is basically in the production phase, so it should be released very soon, hopefully within days.
