ArchiCAD & Solibri Issue Locator
I've tried to find a ArchiCAD 15 add-in for Solibri Model Checker, but without luck.
Does anybody knows if such add-in exists?
I'm trying to utilize the XML file generated in Solibri MC v.7 and open it in ArchiCAD 15.
Sincerely
Lars
7 Replies 7
Djordje
Sincerely
Lars
There is no need for the AddOn, as ArchiCAD reads IFC in ifc, ifc XML and ifczip formats.
Is it ifcXML or just XML file? AFAIK Solibri saves ifcXML, and you can just open it in ArchiCAD. Be sure to check the IFC translator and to set the stuff correctly.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
The XML file is a interference detection report generated in SMC.
In my case hard clashes, between superstructures & MEP.
This XML file should contain information about where these identified chashes are located (within the model).
When imported to ArchiCAD it should then be possible to get a camera view for remodelling/re-engineering purposses. (correct the hard chashes)
Please se the following link for further information about the issue;
http://www.graphisoft.com/products/archicad/interoperability/model_checking/
Djordje
OK, in that case:
- go to http://www.solibri.com/solibri-model-checker/solibri-model-checker-link-for-archicad.html
- download the Add On
- install it
I misunderstood that you can not open the MODEL, not the clash report file ...
Djordje
HP Omen
Djordje
Sincerely
Lars
It looks like you are out of luck.
The add ons at https://ssl.solibri.com/index.php?option=com_docman&task=cat_view&gid=9&Itemid=16 are for 11-14 (2.0) and 11-12
You can check with your reseller, but if it's not on the Solibri web site, then ... you did say in the beginning that you are working on 15, but it's always better to have the version you work on in the signature
You should also check with Solibri.
Djordje
HP Omen
Mats_Knutsson
Mentor
I also discovered this. However Solibri Model Viewer works fine with the .smc file. A little extra step though but not annoying so far for us with the weekly about 15 issues from Solibri.
/Mats
AC 25 SWE Full
Djordje
It is in beta testing and should be published shortly!
Djordje
HP Omen
Solibri Model Checker Link for ArchiCAD 15 is published.
New features are:
- Support for Shells
- Support for Skylights
- Support for Poly Plane Roofs
Solibri Model Checker users can download the Link from Solibri Customer Support Site.
