2008-02-14 04:04 AM
2008-02-14 01:37 PM
2008-02-15 12:11 AM
2008-02-15 12:54 AM
2008-02-15 01:03 AM
2008-02-15 04:29 PM
2008-02-18 01:30 AM
2008-02-18 12:39 PM
2008-02-19 08:44 PM
laszlonagy wrote:Amen.
Yes, this looks like a larger issue than simply DWG/DXF files not working.
You'll probably be fine with XP for quite a while.
I myself do not plan to upgrade to Vista for quite a while.
I would say I will upgrade when some of the below occurs:
1. I have projects which require more than 2 GB of RAM. Then I will need a 64-bit operating system to be able ot use more memory in ArchiCAD.
2. If several of my other programs I must use will be avaiable only on Vista.
3. When I hear from many different sources that Vista is better than XP.
2008-02-21 03:40 PM
