2011-01-24 05:47 AM
2011-01-24 04:58 PM
2011-01-26 11:50 PM
2011-01-27 12:11 AM
2011-01-27 12:43 AM
2011-01-27 02:18 AM
2011-03-27 01:21 PM
Matthew wrote:"heroic lengths with filters", it does sound like AC isn't so straight forward either?.... One can very simply export from Revit to dwf (openable natively in Navis, and natively exported), which carries the geometry very neatly and and required parametric information.
The only guides I know of are in the old fashioned sense of guys like me who know the terrain.
The tricky bit is that there are different ways to set up ArchiCAD for Navis export depending on the desired result. For construction coordination it's mostly a matter of making the layers sensible with options to make it fancy with element IDs and such. For 4D/construction simulation it can get more complex and may require a specially modified/reorganized model. There may even be some extra fancy options to play nice with Artra but I haven't had the chance to explore this in detail.
2011-03-27 07:22 PM
BIMTIM wrote:You shouldn't be surprised. Architects model the buildings for the purpose of design and documentation and not for construction sequencing. They are not likely to do it differently unless the client coughs up the extra cash for the added effort. Design models are as different from construction models as design drawings are different from shop drawings.
If you want to make your model work well for construction simulation, the most important (IMO) factor to consider is "how will the building actually be built" and to model accordingly. I am constantly surprised at models (from both AC and Revit) are modeled with little or no understanding/consideration for how the thing will be built!
2011-03-27 07:48 PM
BIMTIM wrote:DWF is nice but not much different than DWG since Revit still doesn't give the user any control over the layering which is the simplest way to organize the model for Navis. The fine tuning options in ArchiCAD allow one to improve the output to Navis in ways that are difficult or impossible with Revit.
2011-03-27 09:29 PM
