‎2009-04-09 12:55 AM
‎2009-04-09 01:03 AM
‎2009-06-04 05:34 AM
‎2009-06-04 05:38 AM
another Moderator
‎2009-06-04 06:04 AM
ejrolon wrote:Can you post some configuration unit boxes to see how you have it?
Check your export units in AC and your import units in SketchUp both should be the same or you get the problem described. Also you can rescale the project in SU by selecting all objects and using the tape measure click on two points that you know the distance and type the correct amount. SU will ask if you want to rescale the project, click yes and you are done.
‎2009-06-04 06:39 AM
another Moderator
