Dave Jochum
ArchiForma Problem: Save as AC Object Tool
Just used the v.14 version of AF for the first time to make a couple of objects and can't save either as AC objects--the OK button is always grayed out. Doesn't matter if choosing OBJECT, DOOR, or WINDOW. Anybody? Fabrizio?
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.6.1•AC 29 Silicon (latest build)
3 Replies 3
I see the same thing...
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Just disable the option "Keep zoomed detail on Rebuild" from Option/Work Environment/Imaging and Calculation Dialog Window.
I know... the warning message in the Save as object dialog window should be changed in order to better explain this issue... Actually it sound just like a suggestion about the object preview calculation!
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Dave Jochum
Friendly
Fabrizio
Thanks Fabrizio. I can now save to the embedded library, but if I choose another library, the save fails.
Dave Jochum
