ArchiStair Questions
I posted these questions a couple of months ago on the Cigraph site, but haven't received any response, so I'm posting them here in hope of feedback:
1)Within the Stair Selection Settings dialog, under "Display UP/DOWN Strings", there is an eye icon and a pulldown with two options: "- - -" and "UP/DOWN". Is this a layer setting for the text strings (and arrow)? I can't seem to figure out what this setting does.
2)The height of the left rail is always equal to the height of the right -- is this intentional, or a bug? In the US, a (wall-mounted) handrail is 34-38 inches above the nosings, and the rail at the inside of the stair (guardrail) must be a minimum of 42 inches high.
12 REPLIES 12
Stress Co_
It turns on the text and arrow. Don't know on #2.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Seems to turn off the text for me -- not the arrow -- LJY.
Stress Co_
My bad.. your right, it just turns off the text.
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
1. the pop-up menu for the UD-DOWN string is just related to this issue and not to the arrow display status. The string "- - -" means no string.
To hide the arrow line you should choose the oen n.0 in the proper dialog window (see attached image).
2. You cannot define two different height for the left/right handrail (I put this into the list of the next implemente features).
In any case there is a workaround (just a bit boring but it works):
1. enable just the left (or right) handrail in your stair and define the required height.
2. make a copy of the stair in the same position
3. select this copy and enable just the other handrail by setting a different height value
4. hide anything using the proper dialog window (no tread, no riser, no stair body) and you will display just the handrail
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
look at the attached image that shows what you can get using the above workaround...
Fabrizio Diodati
Electric Flute
Hello Frabrizio,
When do you think ArchiStair 2 will out?
The most important add-on for AC in my opinion.
AC26 > AC5 - Win10
Dave Jochum
Is anyone else having problems accessing cigraph.com? I've been trying occasionally for the last month or so with no luck.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.3•AC 28 Silicon (latest build)
Posted: Wed Jan 03, 2007 5:06 am Post subject: Re: ArchiStair Questions
Yes I have been trying to access the Cigraph site several times over the past few weeks to update to the new Architerra release but it appears to be permanently unavailable
fool of a took
Dave Jochum
Fabrizio--Are you having problems with the website?
Dave Jochum
