Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
ArchiStair is ready!
Dear ArchiCAD users,
finally ArchiStair is ready and… FREE OF CHARGE!
Please get any info at www.archistair.com
Friendly
Fabrizio
In order to get info on the way you can receive your free ArchiStair please directly contact our sales manager sending her an e-mail at [email protected]
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
168 Replies 168
Dear Fabrizio; Yes, that solved the problem. Libraries show up correctly. Thanks again for everything.
We have just upgraded to AC9 and installed ArchiStair 1.08 but cant get past an error message when going to edit a stair:
'Cant find Macro: AStair_Swiss, called at line 144 of file Archi_STAIR.gsm'
The report error also tells us that 'XML parsing failed !!! '
This is happening with previously created and new stairs.
Can anyone help??
Thanks
Wavydavy, CSP Architects, York
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Same problem as before:
if that message appears this means you don't have loaded the ArchiStair Library.
Please check between your loaded library if this ArchiStair.Lib folder is missing.
Friendly
Fabrizio
Fabrizio Diodati
Fabrizio
Thanks for your reply.
I checked and the library was in the correct place. The problem seemed to solve itself when I removed ArchiSTAIR.LIB using library manager. After clicking 'remove' the problem went away (the library was still showing in library manager) - Could it be that the library was loaded twice but only showing once?
Working fine now & V powerful.
Regards,
WavyDavy, CSP Architects, York, UK
Fabrizio,
Is it possible to produce a stair as depicted in the attached .pdf? Stairmaker brings up the comment..."Two fills have more then one common edge" when each tread is a separate fill.
Any help is greatly appreciated.
Mats_Knutsson
Mentor
Thank you friendly Fabricio!
Didn't try it until now (shame on me). Really good thing this ArchiStair. Thanks again!
Mats
AC 25 SWE Full
i had a cd with the add-ons for AC9 but the archistair there made the whole stair and then it couldnt place it in the project (floor plan) and i couldnt save it
does anyone know how to solve this problem?
thank you
TomWaltz
Vivi
it sounds like a pirated copy of Archistair and as such may not work properly.
Tom Waltz
I have on occasion had this message as well. I know that the library must be loaded as I have it in the right place but for some reason it doesn't seem to load properly.
The solution that seems to work for me is to go to the Extras menu and select to show the ArchiStair palette. This will load the library if is not loaded and then everything seems to be fine.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
its not pirated copy
my pc obviously has a problem with it because in a friend's works just fine
i ll try re installing maybe both archicad and add ons
thanks both of you
