‎2004-07-10 09:31 AM
‎2006-03-24 04:04 AM
‎2006-03-24 12:26 PM
‎2006-03-24 03:37 PM
Fabrizio wrote:
About Sergio's issue:
I agree with you, you can get a correct 3D display of that stair (BTW the image I sent before to this same topic was made by ONE single stair object) but not a correct 2D visualization.
I will add the feature (only for the pre-defined stair type) to automatically add consecutive overlapping flights and fix the 2D visualization trouble for this particular case (particular but quite common!).
‎2006-03-24 03:48 PM
‎2006-03-24 04:22 PM
‎2006-03-24 09:27 PM
Fabrizio wrote:What do you mean by fills ?
about Jay's issue:
I don't understand the problem... I mean, of course your requested stair shape is not available in the stair pre-defined typologies but is quite simple to get that result using fills.
‎2006-03-24 09:36 PM
Fabrizio wrote:If I save the GSM object that contains an Archistair, place the GSM in a another PLN file and view this GSM I get these Errors (see Attached Jpg).
Once again, this is the right time to post suggestion/request/advice...
‎2006-03-26 01:40 AM
Fabrizio wrote:See image for metallic I beam profile I have made. This is a must in ArchiStair!
‎2006-03-26 11:10 PM
‎2006-03-27 01:25 AM
