I have a cadimage roof covering and need to put 3 downpipes on the one gutter. I have drawn 2 so far - but it won't let me draw any more. The pink nodes for adding in a new downpipes no longer show up. How can I draw a 3rd downpipe? The pink nodes showing at each end of the gutter are for End Angles not for adding new soffits
I Just figured this out. In order to add a new downpipe from a pink node on the cadimage roof covering - first you need to add in a new node to the roof - this will then allow the roof covering to display a new pink node to drag to make a downpipe. Cadimage roof coverings only allow 2 downpipes per gutter.
