2016-11-22 11:15 PM
2017-06-14 09:15 PM
2017-06-14 09:49 PM
2017-06-15 05:43 PM
emerich wrote:The last plugin I have works on Archicad 20 et C4D R18. I you have purchased the plugin before, just send him an email to request to update your C4D serial.
I had used the 'din3d' plugin on previous versions of Archicad (which was incredible btw) but this is no longer available for new versions.
2017-06-16 03:34 PM
2017-06-16 03:54 PM
rodut1112 wrote:+1000
Lets hope that he will update for archicad 21 also. But still graphisoft has to improve this workflow.
another Moderator
2017-06-16 10:50 PM
rodut1112 wrote:What is worse, it's that the Din3d plugin is just the same (improved) as it used to be before. It was a paying add-on from graphisoft. Now it's free and useless
2017-06-26 05:12 PM
2017-06-27 09:48 AM
2017-06-28 10:05 AM
DGSketcher wrote:Its basically the same method as saving as .C4d. The difference is that the scene combine option pop-up and it saves more elements for lights/sun setup. The issue still remains, that you can`t update the file if you run the scene combine command. At least I rediscovered the archicad scene combine in C4d. Thanks.
I have only exported to C4D once to an external consultant. This was done by setting up the 3D view, going to the Photo Rendering Settings window, Select Engine: Cinerender by Maxon, Select the down arrow next to the camera at the bottom of the window and choose Export to Cinema 4D. This creates a 3D file and sub folder of textures. I mailed these to the consultant with a PDF of my rendering and he said everything opened as expected.
