‎2020-07-20 01:24 PM
‎2020-07-20 05:51 PM
‎2020-07-20 06:06 PM
‎2020-07-21 11:34 AM
deivarch wrote:Update: Ok, it turned out that the constellation is a bit trickier.
Question 1: So it seems like that I have to manually place them individually in AC based on a Origin/Placement Marker ... or do you have any other suggestions?
- Yes, if the engineer didn't use the origin point created by the export from AC, then their model will be offset when brought back to AC. You could place an object in your model that you have them "copy monitor" in Revit so it shows up in their Revit file and that way you can orient to it when reimporting.
‎2020-07-22 12:43 PM
JSN wrote:
Wish for Graphisoft and Dev Partners: Of course also support for Rvt 2021 as already discussed in another thread, but also the possibility to auto-detect and load such (nested) linked models from a central model or an addon for Revit to batch process this step with a "send .rvt to Archicad" where this is done automatically.
‎2020-07-22 02:10 PM
LaszloNagy wrote:Sure, in the "Cooperation Archicad Wish Section" or anywhere else?
Could you post this in a separate thread? That way, we can vote on it and if it gets enough support, we can submit it to GRAPHISOFT for consideration. If you just keep it here, it may be lost and overlooked.
‎2020-07-22 10:04 PM
