Archicad Solo 27 and Twinmotion compatibility
Ricardo Lopez
Just to be 100% sure: Is Archicad Solo 27 compatible with Twinmotion's Datasmith Exporter for Archicad?
If not, what exported file format do you recommend for that workflow?
Thank you in advance.
Regards.
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
justdhruv
i am also interested to know about this.
ArchiCAD 20. MacBook Pro 17", 2010
+ core i7 4970k Hackintosh
Lingwisyer
Guru
We just save a FBX out from the 3D window with the same name, then in TM, click on the resync button. It is not live, but I do not feel like you gain all that much with it being live anyway.
Setup info provided by author
