Archipanel - object cannot be created
Hello Everybody.
I would like to ask some help for Cigraph Archipanel,
I got an error message when I attempt to save my panel into a library.
Is anybody with the same situation?
I use Archicad 17 Teamwork licensed version and Cigraph ArchiPanel DEMO.
2 Replies 2
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Hi Andras,
could you be so kind to send me the fill you are using to create the new custom panel?
In this way I will be able to check what is wrong or if there is a trouble in the ArchiPanel Demo...
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Dear Fabrizio,
I tried Vectorial and Solid Fills too and did not work however it works in AC16 perfectly. So, I continue testing in AC16. It seems it has a bug for AC17. Please let me know if I can help to test AC17 if there is alternative way or settings to make it work.
Regards,
Andras
