AutoCAD File need to be imported into Archicad
Hello All
Firs of all thank you for your help. i have 3D CAD file that I would like to import into ARCHICAD 16 (could be as library object or any other way.
Please find attached file located in my dropbox.
https://www.dropbox.com/s/r1jfid3vezaada7/3D-MODEL.dwg
6 REPLIES 6
Eduardo Rolon
IN AC16 go to File-> Libraries and Objects -> Open Object
Select "Browse for a Folder"
in Enable select "DWG"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Step 2
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Step 3
AC29 US/INT -> AC08
another Moderator
Thank you, I have tried these three steps, but for some reason i get only few lines instead of actual crane. see attached screen shot.
Thank you
and Here is how CAD File looks like
Thank you
Eduardo Rolon
Try saving the DWG file as an earlier version of Autocad 2010-2012 to see if that is the problem.
Also the lines shown might be how t will look in floor plan the 3D Object might be complete, if so then you can convert the object to a Morph to have "correct" representation in floor plan.
AC29 US/INT -> AC08
another Moderator
