B.O.Q
hi to every one
this is rose thomas from MUMBAI ,India
i have been making ......rather trying to make A set of B.O.Q. which has a format in excel file ......... i want this same excel format file to be transferred or imported to archicad .
As i see it i have three parts ....in which i can feed in my data ie the writeup 1. Data base
2. you assign property
3. link these properties to your drawings
but this above process has its default settings ie a default format in excel .......i want to customize it ....
CAn any one help me out with this small problem
14 REPLIES 14
But why .....is what i ask .....
any ways there has to be a way out of it ...
other wise i am in deeeeeeep trouble:( .
Please do let me know if any thing more comes up on this .....
I shall look into what you have given me.
thx
Jolly
What you want to do is complicated and cannot be answered in a simple post here - that is why Eric wrote an entire book on the subject. So, you are not in deep trouble - you just need the book. 😉
Sorry ...
What i meant was that the reply column shows "10 replies" but i cannot see them in post. is it related to anything i am not aware of.
jolly wrote:
Sorry ...
Everything after the initial post is a 'reply' - so all of your own posts are 'replies'. The only replies are yours and mine and one from Vistasp asking you to clarify your information. So, you are seeing everything. 😉
OK.
Thanks
Good night .....since its midnight here.
