CI installer update error
Yvonne
Has this happened to anyone before?
AC26 | Win11 | 64 bit | 32Gb RAM | Intel i9-9900K @ 3.60GHz
henrypootel
Hi - yeah if you have this sort of issue, you can always just log a support ticket with us to get help.
If you haven't already though, probably the easiest solution to your problem would be to just redownload the installer using one of the links below:
Mac OS: https://www.mycadimage.com/Downloads/PublicInstaller?os=mac
Windows: https://www.mycadimage.com/Downloads/PublicInstaller?os=pc
Josh Osborne - Central Innovation
HP Zbook Studio G4 - Windows 10 Pro, Intel i7 7820HQ, 32Gb RAM, Quadro M1200
Probably best to contact Central Innovation to see if it is a problem at their end.
henrypootel
