CadImage Door/Window-14 Schedules
I'm new to CI D/W builder-14 and they have changed the way Schedules are done.
And just when I go to create a schedule,
their help center has not been updated for D/W Schedules for 14.
And unfortunately they are closed til the 10th of Jan.
Any hints on where the schedule dialog box can be found?
It's not where it use to be and I'm lost at this point.
BTW All else is working fine with D/W Bldr, so installation must be good.
Thanks
6 Replies 6
AND;
When I log into my account at CadImage it says all my tools are up to date!
And;
My account says my tools are Activated
Brett Brown
Try this. Goto your Project Map, there should be two worksheets automatically set up there. Click on them and when the view appears the Schedules settings box appears out of nowhere The Schedules settings have never been under the cadimage menu. They just appear when needed.
Hi Brett
Thanks for the reply but as attachment shows CI Schedule is accessed from the Cadimage pull down menu in 12 and then you get the CI dialog (in next post) to set up the schedule which will then show up under worksheets.
In 14 I'm not getting the door/window set up menu as I think my first AC-14 post shows.
Therefore there is nothing in the worksheet in Project Map.
Unless I'm more confused than I realize.
Then of course I get this (in 12), which I then can access worksheet in project map.
Maybe I'm missing the obvious equivalent in 14?
Brett Brown
Yes you are right about 12, but in 13 the Door and Window has disappeared, haven't 14 so perhaps it is the same as 13. Sorry can't help you. Try emailing them on the 5th. The Schedules part went backwards as far as I'm concerned from 12 to 13. Perhaps its not much better in 14. Hardly user friendly any more.
